Re: 1066 cab wiring.
Posted by Allan In NE on February 13, 2009 at 17:03:58 from (148.78.243.24):
In Reply to: Re: 1066 cab wiring. posted by doug in illinois on February 13, 2009 at 16:29:03:
Doug,
That relay works just like a Ford starter relay.
Ignition is fed to the little terminal by the ignition switch. When "on", ya gets the voltage at the large "out" terminal.
Does your fuel/air filter gauges work? If so, that rules out the ignition switch.
Also, they had a nasty habit of cooking the hot wires at the plug-in there by the cab pillar on the right side. Where the loom heads upstairs.
Allan
