Re: Broken Part in Farmall A Housing
Posted by Janicholson on February 13, 2009 at 17:23:21 from (66.173.50.129):
In Reply to: Re: Broken Part in Farmall A Housing posted by Tom in Iowa City on February 13, 2009 at 11:11:46:
If it is not leaking now, it is not likely to be leaking in the future. If you drain all the new fluid out, then remove the bolt, then clean it well, you could use the #2 permatex on the bolt to seal the threads, But do not unless it leaks. It either has a bolt in it (as you indicate) or the covering material is smashed up against the hole providing a seal. Best of luck, JimN
