Re: 1066 cab wiring.
Posted by Brownie 450 on February 14, 2009 at 07:29:04 from (216.51.158.151):
In Reply to: 1066 cab wiring. posted by doug in illinois on February 13, 2009 at 15:58:51:
Be sure that the 2 side lights ahead of the cab steps aren't burned out. Use the ohmmeter to check them---then use the voltmeter to see if you have voltage to the light plugs with the light switch on.
Lots of the connectors get dirt in them, & would probably benefit from a good cleaning--at which time you could look for corrosion on the terminal lugs. If you have corrosion to the point of the lugs being no longer usable, you can wire around the connector by cutting the wire on each side of the connector block & splicing in a short piece of wire.
