Re: widowmaker front end
Posted by Hugh MacKay on February 14, 2009 at 09:48:20 from (209.226.106.3):
In Reply to: widowmaker front end posted by james t orth on February 14, 2009 at 08:51:15:
James: Jim has given you most of it. I my opinion no such thing as a widowmaker front end, widowmaker is the guy who put it all together, usually the guy in the seat. Now, if he didn't put it all together, he can change it before he uses it. As Jim said, never use a single front wheel on a loader. If your going to use two wheel narrow front, set those back wheels out to 84" wheel tread, center to center. In all cases load those back tires with liquid, add wheel weights. Lower that CENTER OF GRAVIETY. Two items lower that center of graviety, ballast and Wheel spread. Those are the greatest widowmakers of all, folks running loaders without ballast and wheels set less than 72" centers.
Today's Featured Article - Choosin, Mounting and Using a Bush Hog Type Mower - by Francis Robinson. Looking around at my new neighbors, most of whom are city raised and have recently acquired their first mini-farms of five to fifteen acres and also from reading questions ask at various discussion sites on the web it is frighteningly apparent that a great many guys (and a few gals) are learning by trial and error and mostly error how to use a very dangerous piece of farm equipment. It is also very apparent that these folks are getting a lot of very poor and often very dangerous advice fro ... [Read Article]
Latest Ad: 1997 cub cadet 7275 compact utility tractor 4wd hydro trans cracked block 3500 [More Ads]
