Re: fast hitch adapt. to three point
Posted by Ih fan on February 14, 2009 at 21:09:47 from (70.245.163.21):
In Reply to: Re: fast hitch adapt. to three point posted by GA Dave on February 14, 2009 at 17:54:28:
Mine is very similar to GA Dave's except the "hooks" on the bottom are a little different. Mine have latches with a ring top that can be lifted like the latches on a fast hitch with a tool that you use to reach it from the seat. They will spring load up (or they would if the springs weren't broken), you back into the implement, lift up on the the pins and the latch snaps down. Even though the springs are broken, they will stay up, but just bump them a little and they will fall... takes being real careful to just back in and pick up the pins. Mine has the real short top link as shown. The anti-sway on Dave's looks like chains, but mine is the same as the fast hitch.
It is shown in my parts breakdown, so it's IH.
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
