Re: Next tire question
Posted by Randy-IA on February 15, 2009 at 10:42:59 from (207.177.83.123):
In Reply to: Re: Next tire question posted by Wardner on February 14, 2009 at 22:43:08:
Hi. I have a narrow front.
I never gave the clearance any thought because the parts book indicates both 6.00 and 6.50 will fit. I wanted a smaller tire for ease of steering but I might reconsider the 6.50 size after all for the flotation.
I'm going to use this tractor for plow day events and hay plus other odd jobs around the place that the bigger tractor isn't needed.
You said you don't like the look? Of the spacer or the bigger tires?
Thanks for the reply! ...Randy
Today's Featured Article - Converting from 6 Volt to 12 Volt - by Chris Pratt. It's a common problem for old machines especially when the weather starts to dip below 40 and the tractor isn't fired up as often. You are probably used to the 12 volt Diehard, charged with 200 amp alternator of your 3/4 ton that always is ready and always starts. It's this type of experience that brings about the many queries we get for 12-volt conversion kits. Since only a few kits are available (we sell kits for the ... [Read Article]
