Farmall A gear oli level
Posted by wilson on February 15, 2009 at 10:45:58 from (70.239.85.124):
Got an A in a deal with another tractor Genuine Southern Belle Got them to Indiana could't even unload water in gears froze' all drained now How much gear oil should be in drop axel reduction of I H A? how about filling transmision? Going to sell in spring so Don't need standard post of get a manuel!!Only got the A for swaping rear tires on cockshutt 20 . will tune paint and sell. Thanks
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
