Re: H starting hard
Posted by CNKS on February 15, 2009 at 10:56:19 from (216.144.104.128):
In Reply to: H starting hard posted by edenvt on February 14, 2009 at 18:11:58:
Didn't know what chock was for a minute there, change it to choke. My dad had an H that I drove from the time I was 12 until I was about 20. Starter would barely turn the engine over when hot, it would when cold. Wasn't much of a concern because it had a mag, we would just crank start it. If that is the problem, check out the starter. Otherwise--An H needs very little choke when cold, none when hot except occasionally. It sounds to be like you are flooding it. Also, if your coil is borderline (if there is such a coil), when hot the tractor won't start. This is particularly true if the engine dies, then won't start. The coil has to cool off.
Today's Featured Article - Pitfalls of Tractor Engine Rebuilds - by Chris Pratt. The first pop after you have put the machine together with your own hands is exciting and pleasing. The whole experience can be marred if one moves too fast and makes too many assumptions that they can just use "as is" some parts they should be closely scrutinizing and possibly attended to. In such cases, rework makes what could have been a fun project turn into an irritant or even a nightmare. Minor Irritants To give you an example of an minor but irritating proble ... [Read Article]
