Re: charging battery-farmall H
Posted by Brownie 450 on February 15, 2009 at 14:56:47 from (216.51.158.151):
In Reply to: charging battery-farmall H posted by hank woll on February 15, 2009 at 08:11:51:
If you can get the cover off the regulator, try burnishing the field contact on both sides with some fine emery cloth. Blow out any grit/ residue, & run a corner of a handkerchief [bandana] through the contacts to polish them. This may get the generator going again. The field contact is the one that is normally closed with the engine not running.
