Re: Re: Extracting broken bolts
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Les Repair on April 06, 2000 at 17:43:14 from (206.28.174.149):
In Reply to: Re: Extracting broken bolts posted by Jiff on April 02, 2000 at 09:48:28:
Everybody has their favorite theory. If the bolt is flush, take a flat washer which is the same size as the bolt and weld the washer to the bolt. Many times the heat of the welding will loosen the bolt. Before trying to turn the waher and bolt with a visegrip, tap the end with a hammer to help jar it loose.
Post A Followup
: Re: Re: Re: Extracting broken bolts
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
