Re: Speakin' of plowing and tires ? for all master plowmen
Posted by Hugh MacKay on February 15, 2009 at 18:36:35 from (209.226.106.15):
In Reply to: Speakin' of plowing and tires ? for all master plowmen posted by Randy-IA on February 15, 2009 at 12:02:37:
Randy: Your 18.4 tires should work well with 16" bottoms. 18" is not the width of that tire. Are you saying your tramping landside of furrow with inside of tire? That being the case set wheel tread 4" wider. It should work well.
Either 14.9 or 15.5 should work well with 14" bottoms. There are thousands of plows working on both examples with no problems.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
