Re: Speakin' of plowing and tires ? for all master plowmen
Posted by Jim Allen on February 16, 2009 at 08:17:00 from (209.173.160.22):
In Reply to: Speakin' of plowing and tires ? for all master plowmen posted by Randy-IA on February 15, 2009 at 12:02:37:
Very interesting topic!
Remember the "18.4 " is not the tread width of the tire, but the section width... the width of the carcass from outer sidewall to outer sidewall. I just went and measured a used 18.4 and the actual tread with is about 2 inches less. Oddly, they don't list tread width for tractor tires in the specs as they do with passenger vehicle tires.
When I first started plowing (not all that long ago, as Hugh MacKay will recall because he helped me get the right setups) I tried plowing with a wheel out of the furrow... out of ignorance more than design. Couldn't do it. I was using my little 2810 with a 2-14 and had chloride in the tires as well as some iron strapped on. Couldn't keep the tractor going straight and my first furrows looked like a drunk was at the wheel. Somebody here pointed out... "Hey Jim... ahhh... you want that left tire IN the furrow." I think I could probably make it work now, but why. I can get my 826 set to walk down that furrow straight with my hands off the wheel. I think compaction is an important consideration but maybe it's sometimes outweighed by other factors. But then, what the heck do I know.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
