Re: Questions about Farmall M
Posted by hayfarmer on February 16, 2009 at 09:05:33 from (66.243.244.202):
In Reply to: Questions about Farmall M posted by RDJ Farms on February 15, 2009 at 19:13:51:
You might check it for live hydraulics. Probably a hydraulic pump ahead of the distributor. That is a great addition. Especially if you run a 3 point or loader. If it does have the live pump listen for any rattle in the front cover as they tend to take out the camshaft drive gear. Other then mentioned below, many of the Ms around today have been overhauled at least once and usually "super" kits put in making them an extra 1/8 larger sleeves. All fuel engine generally has 2 fuel tanks, unless it has been changed.
