Re: Farmall H Bolster End Play
Posted by Theman on February 16, 2009 at 11:41:14 from (63.107.135.35):
In Reply to: Farmall H Bolster End Play posted by David G on February 15, 2009 at 18:19:00:
Spacer washers work well. Ten to twenty thousandths would be good. The bolster shaft on my '51 H has 15 thousandths of end play and works well. If you have access to a dial indicator on a magnetic base, you can measure the distance easily. With the sector gear tight on the tapered spline, measure the vertiacl distance the shaft travels until it runs up to the thrust bearing. Subtract 10 to 15 thousandths from this number and that is how thick to make your spacer. If the spacer is too thick, you lock up the shaft, too thin and the shaft hammers going over rough ground. Put your spacer between the thrust bearing and the contoured washer that mates with the shaft fillet.
