Re: Super A electrical question
Posted by Janicholson on February 16, 2009 at 14:10:48 from (199.17.6.128):
In Reply to: Super A electrical question posted by roger_from_nc on February 16, 2009 at 13:53:39:
All questions answered (I think)
A patch on a faulty magneto is to use a coil from a point and coil system to substitute for a magneto coil. (common bridge tactic 9or in some cases permanent non-elegant solution.
The points in the mag are used as points for the coil. It works, but is not the best.
A distributor (opinion) is probably the best solution. Next best is a good mag. (magman on this site, and others do rebuilds and exchanges of IH mags)
A distributor gives a RPM related advance curve fitting the tractor's engine. a Mag is either retarded for starting with the impulse coupling, or in full advance mode for running.
A mag with internal issues in the impulse coupling will not retard the spark, causing starting issues, and or running issues if set to start well.
A seperate issue is the charging system, and battery cables. This tractor needs single ought (1-O gauge) wire with soldered on ends. With lesser wires, it will crank too slow to start well.
John T Charging system check sheet is the best place to go for the charging issue checks. JimN
