Posted by the tractor vet on February 16, 2009 at 16:03:59 from (76.212.226.84):
In Reply to: Best plow for a 450 posted by BigJohn on February 16, 2009 at 12:05:01:
When i bought my old 450D many years ago the first plow was a 311 in 14 inch . That was the first year my buddy had a 450 D and he pulled 4x14 semi mounts , we would plow together and you would think that i should have benn able to flat run over him pulling one less bottom in the same field . Not the case as we were both either in second or third . That fall i found a set of 4x14 540 semi mounts and sold the 311's that fall i found that the 540's pulled just like the 311's same gear. Ya got more done with 4 then 3 . Now if all your going to do is go play then the 311 would be easier on the loading and unloading and a lot shorter .
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
