Re: Gears
Posted by Wardner on February 16, 2009 at 16:20:57 from (4.154.244.48):
In Reply to: Re: Gears posted by Mark on February 16, 2009 at 13:25:21:
Mark,
I didn't do any research on that setup. The auction notice was in my email inbox via an eBay alert. The seller should have included more than one picture.
The best way to make the hydro is to drive a variable displacement pump off the flywheel. That would be a piston pump with a wobble plate that varies the piston stroke. The motor(s) would attach to the tranny mainshaft or one at each final drive housing. With the two motors out of the tractor centerline, you could get a pump with both input and output shaft connections. The output would go back to the PTO.
