Re: H Farmall Hydrualics
Posted by glennster on February 16, 2009 at 16:24:10 from (68.60.242.156):
In Reply to: H Farmall Hydrualics posted by Doversix on February 16, 2009 at 16:00:35:
if you dont need the hydraulics "live" its pretty easy. pick up a spool valve with howevermany outlets you need. from the belly pump, run one of the front pressure outlets to the "in" of the spool valve. run a return line from the out of the spool valve to the hydraulic drain on the bottom of the belly pump. i use a pipe tee and hook the center of the tee to the drain hole, one side of the tee to the return, and a pipe plug in the other, that way you can remove the pipe plug to drain fluid out. to use, pull back on the hydraulic actuator rod and wire it to the full open position. now you will have two way hydraulics from the spool valve.
Today's Featured Article - The Day Tractor Lovers Dream About - by Angus Crawford. The day started at five o'clock on the morning of Friday, the January 29, 1999. My father, my sister, my uncle, my cousin and myself all climbed into my uncle's Toyota van. It was six thirty in the morning and we had a long day ahead. We traveled for six and a half hours to our destination - a little country town with a population of no more then one hundred and fifty people (57 of them being children under the age of thirteen). We arrived hoping to meet up with a man we knew had over one ... [Read Article]
