Re: Speakin' of plowing and tires ? for all master plowmen
Posted by Bob Kerr on February 16, 2009 at 16:24:14 from (216.249.67.127):
In Reply to: Speakin' of plowing and tires ? for all master plowmen posted by Randy-IA on February 15, 2009 at 12:02:37:
I am learning a lot on this subject also but here are a few things you can check on. Finding the centerline of the draft,Checking on the hitch settings and there is an art to that!, making sure all shares are cutting the same amount of width, making sure they are all going the same depth. Just because you have a center hole in the drawbar doesn't mean that is where you put the clevis. You can go out and plow one strip and then come back and start the second one and stop, get a shovel and dig out around the plow to see what it is acually doing. Your tire should not rub the side of the furrow but clear it about an inch or so, if it rubs that causes sidewall wear. Also If the tire is flattening the soil you just turned,(and you have that 1 inch clearance) then the tires are too wide for the shares. Remember this, the wider the tire, the less LBS per sqare inch you have on the tread patch, the less weight per Square inch the more slippage. On the other hand if you have wet conditions the wider may be better but you shouldn't be plowing when it is like that. Keep at it and if you get to a plow day, ask an old timer! Some of those guys sure helped me out.
Today's Featured Article - A Lifetime of David Brown - by Samuel Kennedy. I was born in 1950 and reared on my family’s 100 acre farm. It was a fairly typical Northern Ireland farm where the main enterprise was dairying but some pigs, poultry and sheep were also kept. Potatoes were grown for sale and oats were grown to be used for cattle and horse feeding. Up to about 1958 the dairy cows were fed hay with some turnips and after that grass silage was the main winter feed. That same year was the last in which flax was grown on the farm. Flax provided the fibre which w ... [Read Article]
