Re: '42 M charging question?
Posted by John T on February 16, 2009 at 18:29:20 from (71.55.26.69):
In Reply to: '42 M charging question? posted by TedD17 on February 16, 2009 at 17:36:40:
For sure it could be a belt or badly worn pulley problem, always try the easy simple things first like a good n tight belt and a good ground (on BOTH the Genny and Voltage Regulator) and all good wiring connections. If she still dont charge try Bob M's Flow Chart and/or my Troubleshooting Procedure to systematically work through the charging system, genny and Voltage Regulator etc to trace down the cause of non charging......
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=jd&th=304795
Para 5 will easily tell hot to determine if its a genny versus the VR's problem
John T
