The oil fouled plugs indicate that you have a serious problem. A cylinder leakage test will pinpoint where the problem is. If you apply compressed air to the cylinder with a cylinder leakage gauge, you will hear the air escaping to the crankcase (bad rings, piston, cylinder), to the intake manifold (intake valve), exhaust manifold (exhaust valve), or cooling system (head gasket/block). The oil fouled plugs would most likely indicate a problem with the piston rings or piston. Excessively worn intake valve guides could also cause oil fouling but not to this extent. A good reading for a cylinder leakage test is 90% (i.e. if you apply 100 psi the cylinder would hold 90 psi). Anything lower than this indicates a worn engine and major engine repairs.
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
