Posted by ScottyHOMEy on February 17, 2009 at 06:02:23 from (71.241.194.79):
In Reply to: Farmall A valves posted by doggonetractors on February 17, 2009 at 02:00:24:
Not sure where you're looking for valve dimensions/specs. Only thing I've found so far is in the IH service manual, which calls for a length of 4-53/64, or 4.828, which is about in the middle of the range you're talking about. Maybe that changed over time, but I haven't found it yet.
Within the variance you give, as long as you have your tappet clearance set right, the only difference with a shorter valve (we're talking 8/100 between new and old and 4/100 from spec) and good faces on your rocker would be a little more spring compression.
Yes, there is a lot of compression on those springs, and somebody will call me on it if I'm wrong, but I think you'll be fine.
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
