Re: My excitement was short lived
Posted by D Slater on February 17, 2009 at 08:25:03 from (71.164.63.223):
In Reply to: My excitement was short lived posted by neblinc on February 17, 2009 at 07:53:13:
Other than what Jim said the washer looks like the one used with the later update inside axle roller bearing. It or any washer doesn't belong with the ball bearing you have. Only other reason I can think of for a spacer, is if the bearing locked up sometime and inside race spun on axle and caused wear on sholder of axle and flange of bull gear. If to much wear the bull gear and axle wouldn't tighten agian inner bearing race when bolt with big washer was tightened. Without seeing this is all a best guess.
