Re: My excitement was short lived
Posted by Dave S. on February 17, 2009 at 10:18:50 from (208.92.168.4):
In Reply to: My excitement was short lived posted by neblinc on February 17, 2009 at 07:53:13:
I may have a good gear in the garage,will look tonight. I had to grind down the bull gear to get it flat again because it was run loose. Then had to add shim washers between the bull gear and bearing so the thick washer would tighten against the bull gear and not the axle. Otherwise the bull gear would be loose and allow the axle to float in and out. I have used it for 2 1/2 years plowing, mowing, raking and bailing hay with no problems.
E-mail me and I will let you know if I find a good gear.
