Posted by Janicholson on February 17, 2009 at 16:58:23 from (68.112.156.69):
In Reply to: MD Questions posted by BruceS. on February 17, 2009 at 16:42:22:
There should be a switch to ground the mag (as does the switch on the butterfly shaft. The starting system is complex, but mot obscene. I would say if it runs on Diesel, it will be possible to make a go of the gas stsrt system. If it runs well, buy it. It needs to be operating with a bit of load for an hour or more to be sure things are OK. Opinions vary, but the method of shutdown after work is best done on diesel at idle for no less than one minute if operated for ten minutes, and no less than 3 minutes if well warmed up. Diesel operation is far cooler than running on gasoline, and has the advantage of not heating the compression release third valves as well. I believe this as fact. It is worth more than 1500 if the tires are good. Less proportionally if it can't be started on Diesel, or has bad tires. I would like another one! JimN
Today's Featured Article - Women and Tractors - Tractor Engine Repair - by Teri Burkholder. One of the great things about working on a tractor engine with your other half is that you know what he is thinking of at all times and can anticipate his every move and his next thought of what he will do. With Ben, anyway, I can tell! He'll be busy working and I’m handing him tools and he says, "give me that..." and I’ve already got it in his hand or "hand me that....."and I’ve got the portable light right where he needed it placed to see. "Run in the house and get me a...."as I open th
... [Read Article]
Latest Ad:
[More Ads]
