Re: MD Questions
Posted by Brad in WI on February 17, 2009 at 17:08:50 from (24.164.253.14):
In Reply to: MD Questions posted by BruceS. on February 17, 2009 at 16:42:22:
The wire that runs from the mag to the manifold is a cutout wire that grounds the mag out to prevent constant spark to the plugs.
No ignition switch is necessary as on gas side and throttle down. engage starter and play with choke and it should run. (giving clean fuel, new points, clean carb, etc.)
To shut it off, idle down on diesel and switch back to gas. with throttle lever in gas mode (diesel off) pull the fuel switch lever back to ground out the mag.
LEAVE THE LEVER TO SWITCH FUELS IN DIESEL TO PREVENT WARPING OF THE VALVES AND SEATS.
