Re: Did International forget rear axle grease fitting?
Posted by Brad in WI on February 17, 2009 at 17:30:12 from (24.164.253.14):
In Reply to: Did International forget rear axle grease fitting? posted by SASmith on February 17, 2009 at 17:18:44:
I am not familiar with the 484 model but on H thru M series there was a grease fitting that was on the outer part of the axle housing that often got broken off. maybe check out your axle bearing retaining cap and see if there is a spot that may have once contained a grease fitting.
