Re: Did International forget rear axle grease fitting?
Posted by JimB2 on February 17, 2009 at 17:43:37 from (99.241.179.24):
In Reply to: Did International forget rear axle grease fitting? posted by SASmith on February 17, 2009 at 17:18:44:
Hi, the last tractor that we owned that I remember having an outer axle bearing grease fitting was 300U build in 1957/58. The B414 we purchased in 1962 never had one and also 454 (similar to 484)purchased in 1972 and still running strong. I am not sure but I thought a small amount of Hytran from transmission/rear end was supposed to lube that bearing. Looked at CaseIH parts on line and there is an inner and outer oil seal on the rear axle, so is inconclusive as to the presence of Hytran to that outer bearing. Maybe someone else will give us the correct answer.
JimB
