Re: More questions on a Farmall M
Posted by Janicholson on February 17, 2009 at 19:18:05 from (68.112.156.69):
In Reply to: Re: More questions on a Farmall M posted by RDJ Farms on February 17, 2009 at 19:07:25:
With the small tank, it was/is a distillate. No issue they run fine on gsoline. The part number for the head is under the valve cover, Not visible. If you can see in the sparkplug holr with a tiny light you can see if it has dome pistons. It probably has been rebilt at least once, so many opyions are available. If it runs and carries good oil pressure, it is worth 1000 to 1500 depending on tires, and how much you want it. JimN
