Re: tire chains
Posted by Hugh MacKay on February 18, 2009 at 13:51:18 from (216.208.58.142):
In Reply to: tire chains posted by dspace52 on February 18, 2009 at 13:37:25:
dspace: Tire width and diameter is the way to spec out wheel chains. The tire must have a size on it somewhere. That is most likely first thing you'll be asked when you go to order chains.
If you can't find any answers, pull a rope across the tire face down to about 2-1/2 to 3 inches from rim. That should give you cross chain length. Then calculate the diameter at the point 2-1/2 to 3 inches from rim. Then calculate circumference at that point. That should give you aproximate length of side chain. Best to make that side chain 12" over length. You can always cut off excess.
