Re: D Slater
Posted by D Slater on February 18, 2009 at 15:09:36 from (71.164.63.223):
In Reply to: D Slater posted by Pete in Nev on February 18, 2009 at 12:18:54:
If have the one with drop boxes and you want tractor to go the same direction as a normal MD and it goes the other way now, you can remove the drop boxes on axles and install the wheels on axle. If you want to keep the drop boxes, the differential needs turned to other side of pinion gear. Think you need a transmission cover and shift forks that moves shifter and shift rails to other side for last. Can't help with the parts. Jim Becker or Harold H that post here are from the part of country tractors were used in I think. Maybe they could help.
