400 hyd. and power steering problem
Posted by rtb321 on February 18, 2009 at 15:17:24 from (69.207.115.108):
i"m working on a 400 that the hyd. pressure pulsates when you push the levers forward but has a solid 850 psi when i pull them back. the power steering also pulsates except when you hold the levers back, than it seems to work ok. can anyone point me in the right direction on this?
