Re: Nother question,this time about the hubs on M front end
Posted by Randy-IA on February 18, 2009 at 15:41:00 from (207.177.83.77):
In Reply to: Re: Nother question,this time about the hubs on M front end posted by D Slater on February 17, 2009 at 18:49:46:
You nailed it! I went out and looked after work and it was as you said. Thanks! Now to find another DB version. ...Randy
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
