Re: Amp Gauge farmall H
Posted by Janicholson on February 18, 2009 at 16:05:52 from (66.173.50.172):
In Reply to: Amp Gauge farmall H posted by narrowfarm on February 18, 2009 at 13:33:50:
Tractorman's idea is OK. I would find the output of the alt (usually stamped on the housing) and use a AMP gauge just a bit bigger in capacity. Yes it will not wiggle much, but they usually don't wiggle at all, they stay just above center and only when the battery is a bit low from cranking (not common) would it show much charge. But if too small, it can be burnt up if (for instance) you use it to charge/jump another vehicle, or start it with a dead battery. JimN
