Re: International 574 stuck in gear
Posted by JimB2 on February 18, 2009 at 19:39:59 from (99.241.179.24):
In Reply to: International 574 stuck in gear posted by Sevillian on February 18, 2009 at 18:58:05:
Hi Sevillian, I have had the Rev/Hi/Lo shift lever stick on a 454 (same as 574) between Hi and Lo. Where it was not in any gear. Just had to wiggle and jiggle shift lever and it went into LO range. DO NOT FORCE THE LEVER. If it is stuck in HI and you can move the shift lever into LO or REV and it stays in HI then maybe you sheared off the range shift lever inside the transmission. Bernard Le Mechano had a procedure to change the range shift lever thru the PTO clutch access hole.
Hope this helps
JimB
Today's Featured Article - Memories of a Farmall C - by Monty Bradley. When I was a child, my grandparents lived on a farm owned by a Mr. Walters. The crops raised were cotton and soybeans, with about forty head of mixed breed cattle. Mr. Walters owned two tractors then. A Farmall 300 on gasoline and a Farmall C, that had once belonged to his father-in-law, and had been converted from gasoline to LP Gas. Many times, as a small boy, I would cross the fence behind the house my grandparents lived in and walk down the turn row to where granddaddy would be cultivati ... [Read Article]
