Re: 1939 Farmall A Electric Start
Posted by gene bender on February 19, 2009 at 02:44:49 from (67.55.226.75):
In Reply to: 1939 Farmall A Electric Start posted by WildWill on February 18, 2009 at 14:50:45:
First starter on the A factory was FAA 18322 March 25 1940. Yes there were field kits avail and then they left factory with flywheel ring gears and hole for the starter so all ya had to do was install staerter and wire it. Sure beat changiing bell housing and flywheel in the field.
