Re: tractor vet others electrical
Posted by charles todd on February 19, 2009 at 12:17:21 from (205.242.95.136):
In Reply to: tractor vet others electrical posted by lenray on February 18, 2009 at 14:06:44:
WD-40 is only a "moisture displacement" spray. If you drive your tractor into a pond it is good for drying out the ignition system. As for electrical connections, I'd do one of two things. Use some scotchbrite on the terminals, followed by contact cleaner, then use silicone grease on the terminals and inside the sta-kon's. Or scotchbrite, contact cleaner, solder, and heat shrink. I prefer the solder method. It is slower to install, and slower to repalce, but you will NEVER have to second guess the connections.
Charles
