Posted by Janicholson on February 19, 2009 at 13:56:13 from (199.17.6.128):
In Reply to: B no spark posted by farmall guy on February 19, 2009 at 13:46:43:
A mag with a partila triggering impulse coupling will do that. I suggest listening to the mag while cranking, A distinct click noise should happen every time it is to fire at starting speeds. If it does not, I would remove it and chack the impulse coupling on the bench. Ground the center wire in the cap to the body of the mag, then rotate the drive, if it springs as turned, then snaps, it should spark. It should be OK if rebuilt. Alternators are not at all related to mags, and do different things. JimN
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
