another m question
Posted by TedD17 on February 19, 2009 at 18:14:24 from (98.212.254.201):
well so far you guys have led me in the right direction...now...at an idle or half throttle setting it will sputter then backfire a little then goes back to normal...then a minute later it will do the same thing..normal running operation is great, just when it sets it does this...i can leave it at the lowest setting on throttle and it'll still run, just sputters and backfires once in awhile..governor problem or carb or??????? thanks everyone again!!!
