Re: 6.9 diesel in tractors?
Posted by billde on February 19, 2009 at 18:39:57 from (72.26.91.191):
In Reply to: 6.9 diesel in tractors? posted by mm in MI on February 19, 2009 at 18:10:12:
If you are refering to the V8,you have that backwards, the engine in earlier Ford trucks looks just like the ones used in IH tractors. The early powersmokes were a modified IH diesel.
