Re: trans/rearend lube drain
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Village Blacksmith on April 06, 2000 at 23:26:02 from (205.188.201.75):
In Reply to: trans/rearend lube drain posted by Stillcrazy on April 06, 2000 at 21:18:45:
The drive gear drain plugs will only drain the drive gears. You will have a separate drain plug on the bottom of the transmission/differential to drain the main gear box.
Post A Followup
: Re: Re: trans/rearend lube drain
