Re: Rear hydraulic remote
Posted by mkirsch on February 20, 2009 at 06:41:35 from (128.221.197.21):
In Reply to: Rear hydraulic remote posted by glennster on February 19, 2009 at 15:35:36:
You need a spool valve with "power beyond."
Install the valve in a convenient location.
Detach the hose going from the pump to the IN on the FEL valve.
Attach this hose to the IN on your new valve.
Run a hose from the power beyond port on the new valve to the IN on your FEL valve.
Run a hose from the OUT on the new valve to the fill plug (or a level check plug) on your hydraulic reservoir.
Run hoses from the work ports on your new valve to the rear of the tractor.
Install quick disconnects on the ends of these hoses at the rear of the tractor.
