on the side pump toward the front of pump there is two plugs one is drain plug one is level plug,as far as the pressure gauge goes it near the top of plunger head in line just below return line. Pressure gauge not available from CIH reproductions are pricey,I use engine oil pressure gauge with mounting studs cut off not original but works great. Good luck Scott
Today's Featured Article - Tractor Profile: Farmall M - by Staff. H so that mountable implements were interchaneable. The Farmall M was most popular with large-acreage row-crop farmers. It was powered by either a high-compression gas engine or a distillate version with lower compression. Options included the Lift-All hydraulic system, a belt pulley, PTO, rubber tires, starter, lights and a swinging drawbar. It could be ordered in the high-crop, wide-front or tricycle configurations. The high-crop version was called a Model MV.
... [Read Article]
Latest Ad:
[More Ads]
