Re: Re: Re: Re: Plows for Farmall M
[ View Follow Ups ] [ Post Followup ] [ Return to Farmall & IHC Tractors Discussion Board ]
Posted by Pat on April 07, 2000 at 05:40:48 from (63.227.13.47):
In Reply to: Re: Re: Re: Plows for Farmall M posted by The Red on April 06, 2000 at 11:02:00:
According to my boss (an electrical engineer) the lights should require as much amperage at dim as bright, because a resistor is used to reduce voltage, rather than a second element drawing less wattage/amps. HOWEVER, since the 57 year ammeter on the M and my $70 voltmeter agree, I vote with the Red.
I don't worry much about the discharge, the generator wasn't hooked up for 4 months, and I only had to charge the battery once. And that was right before I "found" a new regulator.
Post A Followup
: Re: Re: Re: Re: Re: Plows for Farmall M
Today's Featured Article - Hydraulics - Cylinder Anatomy - by Curtis von Fange. Let’s make one more addition to our series on hydraulics. I’ve noticed a few questions in the comment section that could pertain to hydraulic cylinders so I thought we could take a short look at this real workhorse of the circuit. Cylinders are the reason for the hydraulic circuit. They take the fluid power delivered from the pump and magically change it into mechanical power. There are many types of cylinders that one might run across on a farm scenario. Each one could take a chapter in ... [Read Article]
