This is one of those type question youre apt to get varied opinions on, so I will JUMP RIGHT IN AND kick it off with an engineers perspective.
1) To get all the benefits that improved elec switch has to offer n get the most "bang for the buck" I recommend (versus the old stock coil) a matching high energy high voltage coil such as their flame thrower series BE SURE N LET PERTRONIX MATCH THE COIL FOR THE SWITCH as some coils may draw more current n require a higher current rated switch.
2) If you run the elec switch and a high energy high voltage coil, Id widen the stock plug gap to more like at least 0.035 to 0.045 or even a bit more. With the higher energy ignition and wider plug gap you end up with a wider hotter fatter spark which discharges more energy (volts x amps x time) across the plug gap then a stock ignition...THATS JUST PHYSICS
3) Since youre running at a higher firing voltage if you widen the plug gap, you need good quality plug wires and a good clean dirt n oil n moisture n crack free distributor cap. Go with what Pertronix recommends which may be 7 or 7.5 mm etc wires but too big of a wire (8mm) might not fit just right in a stock cap CHECK WITH PERTRONIX
DISCLAIMERS:::::
From an engineers standpoint I wouldnt expect much more if any net HP gain BUTTTTTTTT I would expect better starting and idle performance versus the stock ignition
DO NOT wire it at the wrong polarity you will let the smoke out grrrrrrrrrrrr
Use a good heavy duty battery and 00 gauge battery n starter n ground cables (regardless of any ignition on a 6 volt system) cuz if shes hard to crank n the battery voltage drops drastically the elec ignition may not perform correct
DRAWBACKS a) IF the old points burn you can file them n probably get back to the shop butttttttttt if the elec switch stops YOURE SCREWED b) The elec switch costs more
ADVANTAGES Better starts n idle,,,,,,no points or condensor problems,,,,,more spark gap energy (volts x amps x time) across a wider plug gap is available for that wider hotter fatter spark AGAIN those are the laws of physics IM NOT SAYING THATS NECESSARILY BETTER its just a fact
Your tractor youre choice, best wishes BE SURE N LET PERTRONIX MATCH THE COIL N SWITCH FOR YOUR GROUND AND CURRENT RATINGS ETC
Today's Featured Article - Trenching With a Plow - by Staff. Introduction: This interesting information came from one of the discussion forums here at YT. We thought we should place it up front so it could be read by anyone interested in putting old iron to work. [Editor] I tried something new today, and it worked so well I thought I should post it - in case it might help someone else. I'm running 100 yards of 4" drain pipe from the gutter downspouts of our house to a pond down the hill. This should hel
... [Read Article]
Latest Ad:
[More Ads]
