Yes, on the cam on cars they play with tac and dwell to increase power/speed, but the trick is the timing gears meshing to correct adjustment in the gearing you want. I am assuming you can do the same with a tractor, but you would have to change the gear on the end og the cam with one that can be adjustable, like you say a half tooth/tooth? On the carb. I think as you say will work, but you probably would have to play with that also? Thanks!
Today's Featured Article - The Ferguson System Principal An implement cutting through the soil at a certain depth say eight inches requires a certain force or draft to pull it. Obviously that draft will increase if the implement runs deeper than eight inches, and decrease if it runs shallower. Why not use that draft fact to control the depth of work automatically? The draft forces are
... [Read Article]
Latest Ad:
[More Ads]
