Re: Changing brake band Farmall Super AV
Posted by Athol Carr on February 21, 2009 at 16:47:07 from (219.89.239.25):
In Reply to: Changing brake band Farmall Super AV posted by Luke in UT on February 21, 2009 at 14:07:55:
You have to remove the reduction gear housings to get at the brake drums. Obviously IH didn't think it would happen very often as it is a pain in the neck exercise, one really needs a shop crane to move the bits. I had one oil soaked brake band, so had both bands relined. It took us 2 hours to get the old oil seals out of the gearbox casting but probably another hour to get housings and wheels back on. You have to remove so much other gear to get the back end apart. Ih did not make maintenance easy.
