Make sure that the hyd. level is up to or above the full line , start the tractor and run the engine at around 2000-2200 and turn the steering wheel to the left and keep turning it this will help to bleed the air out and it should pick up prime . the sump check plug may be seeping or she maybe starting to suck some air thru the O/Ring between the speed transmission and the range transmission . Now i do not figure that you want to split her for and O/Ring unless it is really bad so you can add a few extra gallons to the hyd. sump this will not hurt a thing. This will help with a higher oil level. Also the MCV pump maybe getting a bit weak or there maybe a stuck flow control valve. Try what i have told ya and see if she picks up prime and let me know .
Today's Featured Article - Hydraulic Basics - Part 2 - by Curtis Von Fange. In the last entry to this series we gave a brief overview of hydraulic system theory, its basic components and how it works. Now lets take a look at some general maintenance tips that will keep our system operating to its fullest potential. The two biggest enemies to a hydraulic system are dirt and water. Dirt can score the insides of cylinders, spool valves and pumps. Wate
... [Read Article]
Latest Ad:
[More Ads]
