Re: Changing brake band Farmall Super AV
Posted by P and R Pete on February 22, 2009 at 06:51:50 from (173.86.63.108):
In Reply to: Changing brake band Farmall Super AV posted by Luke in UT on February 21, 2009 at 14:07:55:
Luke, I have some pictures. I'm not sure exactly where you are in your process,- if you're just changing your brake bands, or if you've taken off your drums yet or run into problems at that point.
Here's a pic of how I supported my final drive casting to extract it, using an engine hoist. The nice part is that you can raise or lower it incrementally to get it to exactly mate back up, and it's fairly well-balanced so that the differential shaft can go back in straight without any straining, or putting any sideways torque on the shaft.
third party image
My left brake band was saturated with oil- the right not so bad. But I thought that as long as I was this far, I might as well do all the seals at the same time. First step is removing the drum. It has a set-screw held tight by a jam-nut. Loosen the jam nut, then back out the set-screw.
third party image
The drum is not a press-fit, but it is keyed, and mine was on tight, and if memory serves me, I used a pry-bar in the lower right where it can be gotten behind the drum, and then gently pried, while spinning the drum to pry it 'all around', I was able to loosen it until it was able to be walked off the shaft.
Next was taking out the differential shaft. (I'm showing pics of the left side, didn't take pics of this process from the right, but it's the same). When you take off the cover (the only thing that holds the shaft in)...
third party image
the shaft and the bearing will come out when you *pop* the end of the shaft with a sufficiently heavy piece of wood. It is NOT a press-fit, but in a previous post, a guy's was 'stuck' somewhat.
third party image
This exposes the seal in the outer casting...
third party image
You can see mine was in backwards from a previous owner. The lip is supposed to face the oil within the casting where the bull gear is.
Here's the seal in the differential/tranny case.
third party image
I couldn't get it out without taking off the center differential housing..
third party image
which exposes the inner seal on the right...
third party image
But this takes special precautions, so if you're going this far, start another thread, (as this one is dropping) and we all can go from there.
I sent you my e-mail, so if you don't have dial-up, I can send pics that way.
