front pulley
Posted by Chief 83 on February 22, 2009 at 18:13:29 from (24.20.242.22):
My cub project just keeps getting worse. I bought a cub that was supposed to have a good motor thinking I'd just switch it into the family cub that definately has a bad engine. Well the "new" one is just about as bad. Rod and mains are scored and so is the crank, head is cracked--and on and on. We will fix it but as usual it is not as inexpensive as I'd planned. Todays problem is getting the crank out. Had a very hard time pulling the front pulley off the crank. Man was it on there. Heat and a really big puller finally got it. The question now is on reassembly how the heck to I get it back on?
Today's Featured Article - Tuning-Up Your Tractor: Plugs & Compression Testing - by Curtis Von Fange. The engine seems to run rough. In the exhaust you can hear an occasion 'poofing' sound like somethings not firing on all cylinders. Under loaded conditions the tractor seems to lack power and it belches black smoke out of the exhaust. For some reason it just doesn't want to start up without cranking and cranking the starter. All these conditions can be signals that your unit is in need of a tune up. Ok, so what is involved in a tune up? You say, swap plugs and file the points....now tha ... [Read Article]
